simond wrote
All depends on the storage capacity and the cylinder stat setting for replenishment and of course the size of the Hex .
What is an automatic variable cold mix valve if I may ask?
Do you mean a TMV ?.
Once you drop the storage temperature to safer levels then no singing and dancing elaborate temperature controls are needed in my view.
If the maximum storage temp is 60 then a PHE is not going to deliver a higher temperature than this no matter how low the flow through it on the secondary side.
If the customer wants a significant flow rate and you have downgraded the heat bank to 65C it will lose temperature quickly and deliver low water temp HW.
The Nu Heat unit has no automatic variable cold mix valve
and no varispeed pump, so it has little chance of masking the side effects of a low water storage temperature that you advocate when significant flow rates are demanded of it. The cold mix will remain unchanged at the output.
