Balenza said:simond wrote
If the customer wants a significant flow rate and you have downgraded the heat bank to 65C it will lose temperature quickly and deliver low water temp HW.
All depends on the storage capacity and the cylinder stat setting for replenishment and of course the size of the Hex .
The Nu Heat unit has no automatic variable cold mix valve
What is an automatic variable cold mix valve if I may ask?
Do you mean a TMV ?.
baggy99 said:Since I (in my innocence) started this thread, may I bring it back to the original topic? I tested the flow rate today and found I have 33 l/m, which IMHO is pretty good?
Which leads me to another question..... Is it perhaps too high? Should I be looking to fit some sort of flow/pressure limiter on the TS? Advice please.
As to the ongoing "discussion" which has taken over this thread, I am genuinely interested in the system proposed by DrD, even if the technical issues you are all discussing are way over my head. Perhaps DrD could post a detailed plan of his proposals and the rest of you could constructively point out how it could be improved, if possible?
Thanks.....
Get a room.Doctor Drivel said:Only Balenza understands thermal storage on here. We could get together and suggest a good solution. Need to go to bed.
Doctor Drivel said:I wonder how much Fumb paid for the plate heat exchanger? And who He got it from. The average merchant will not supply such things.
You did OK there - the last one I bought was only about 10% less than that.fumb said:I paid £76 plus the dreaded
