In the midst of replacing the heater control valve.
But after seeing the state of the coolant, I decided to do a full flush.
It's a bit of a pain on the KA. But I eventually got to the lower rad hose, and drained it.
It takes around 5l and 2.5 litres came out. I also gave the hopper box a good clean and put it back on and filled with some distilled water to begin the first flush.
Now, this it where it gets curious. I filled it between the max/min line and ran the engine.
I squeezed all the hoses and it produced some bubbles. I could feel the pipes getting hotter around the engine but not the rad pipes. I also kept topping up the header tank as bubbles were produced and the level seemed to drop. But at one point the level rose and it was above the max line a bit.
I was keeping the cap off while this was all taking place to let any bubbles escape. Then, I notice the water level rising a bit too much, in a panic I switched off the engine and at the same time the water level suddenly dropped.
My assumption is that the thermostat opened and started feeding water to the radiator, as at this point the radiator pipes started getting warm. So I kept the engine running and then I loosely put the cap back on. After a bit more running I decided to check under the cap and took it off. And the level was rising again, until suddenly it started overflowing.
1) Did I cause the overflow by suddenly taking the cap off while it had built up pressure?
2) What other issues could have caused this that I should check?
I kept adding water as the level fluctuated, but maybe I added too much? At one point it seemed to be above the max line.
3)The rad fan did not come on at all. The pipes to the rad got warm/hot but the rad did not feel hot to touch. But still no fan.
