You can buy a concrete common where I come frombut I don't know if you can use them below damp
same here known as concrete commons and can be used below dpc[/quote] what colour?
similar to a floor beam infill sliver , i never seen them being used on a outer skin like i said the house be being rendered or being built up northgreyish white colour same as concrete block
i think you mean a footing brick , white smoothish solid, yea but the question was under damp not under groundgreyish white colour same as concrete block
anything bout bricks esa dont hestitate to ask me have good weekendShould the first course below DPC be layed across the cavity or in the normal open cavity formation ? and do you use conc common brick for the first course or concrete block ?
hehei think you mean a footing brick , white smoothish solid, yea but the question was under damp not under groundgreyish white colour same as concrete block
up north the ground is under damp![]()
ryarsh thats the name i was thinking of,hey brikie before the inspector inspects my new small extension do you think i should take out the half bats each corner of old build and bed new damp into it or just chase out a groove its a slate damp on old ?Are we talking Ryarsh silica bricks or actual concrete bricks?
who said about laying soft bricks under damp,sand face flitton is rock hard you ever tried cutting a few out with hammer and chisel? scroll back to some of the replys and your notice commons ie solid frost proof are commonly layed under the damp albiet a sand faced ones ,nose all do you know what a sand faced flitton is?external ground level should be 150mm (min) below dpc.
this generally leaves 2 bricks visible below damp.
it is these 2 courses of bricks that are the most vulnerable to frost.
the bricks lower down may absorb water also, but are not as exposed to the freezing weather.
only a complete fool would risk laying an absorbent brick below dpc, regardless of b'regs or architects specifications.![]()
not me noseall , maybe your getting a little agitated because you was proven wrong not only by me but a few others to,if your not busy the weekend scroll through them and take a look your self with out accusing folks of being paranoid , iam off to the pub and probaly hear a remark by 5pm ,(i layed 3000 7 newton blocks on friday) have a good onein my latest post i made absolutely NO reference to the use of flettons.
i merely stated a good building practice and NOTHING else.
you seem to be a little paranoid fastnotroll.
come on you gunnnersand do you use conc common brick for the first course or concrete block ?
read this fastnotroll.
woody advised not to use common bricks. in certain parts of the country 'commons' are regarded as an inferior soft clay brick. this was good advice.
it was YOU who has gone off on a crusade about fletton bricks and their uses.
i merely backed up the advice about the problems associated with using soft clay materials below dpc. ffs.![]()
