'Frost' inside integrated CANDY fridge
stl
27 Sep 2005
I have 'frost' building up on the inside rear wall (white plastic) of the fridge at the upper levels only.
The compressor seems to be running all the time and the temperature at the rear of the fridge about 1.4 degrees. This is with the Thermostat on a low setting of about 1. When changing the thermostat dial to higher numbers, the temperature doesn't change significantly. There doesn't seem to be any auto de-frost happening. The seal is generally ok around the door and the fridge is about 6 years old.
The fridge is a CANDY Hoover under the counter fridge - model No. CRU 160/1 AK.
Does anyone have any views on what this could be and how to repair it.
Simon
