Hi all - first time poster and have zero knowledge about boilers/heating systems, so please be gentle
Our boiler (Baxi EcoBlue Advance 19 Heat Condensing Boiler) is located in an attached garage with a separate Honeywell frost stat wired in next to it. In very cold weather, the frost stat is coming on and heating up the radiators/hot water in the house for long periods of time, several times a night.
Our central heating programmer/timer is a Honeywell ST 6400 (C) system and it seems that whatever programme was on last before the frost stat kicks in, whether it be the hot water or heating, is what will come on when the stat is activated, even when we put them both in the "off" position on the timer. (The timer is usually set in the "once" position for both heating and hot water and we put the heating only on in the afternoon/evening on the "continuous" mode and switch it off when we feel the house is warm enough).
Ideally we do not want neither the hot water or heating on when we are in bed.
Do we need a pipe stat fitted to the boiler to prevent the radiators coming on? or could it be a problem with the diverter valve in the boiler that is making the heating or hot water come on?
Do I contact Baxi? (as the boiler is still under warranty) or the Heating Engineer who fitted the boiler?
I did contact 2 other local Heating/Plumbing companies who both told me that it was normal for the heating to come on (for prolonged periods) when the frost stat kicks in and that I didn't need a pipe stat. Reading some posts on this forum, the advice is that I do.
Many thanks in advance!
