perfect thank so much!
so in order to figure out which I'm unplugging, I guess if the topmost element is on, it should heat up quickly but also not give out much hot water?
@john, how comes? its white, brand new.
Don't worry about it.because I didn't really know which forum had the most users and was looking to solve this the quickest,
I was going to delete the redundant thread but it turns out they don't allow you to.
simply because it doubles their chances of getting the right answer, before you prattle on with your usual follow up... No I for one do not visit the other forums.Another one asking the same question on two different forums! And getting similar answers. Why do they do it?
Quite right too, as far as I'm concerned, anyone asking a sensible question (ie one they don't know the answer to) is welcome here and if I were on other forums I'd welcome them there too.because I didn't really know which forum had the most users and was looking to solve this the quickest,
No insulation is perfect so it will start cooling down and switch on again. If you are not in during the day it is better to time if off when you leave and on again shortly before you get back.Then it has very good insulation. And if you don't get cheap off-peak electricity your timer brings no benefit. You may as well just leave the immersion heater on all the time.
As soon as the water has been heated to its target temperature, the internal thermostat will turn it off and it will stop using electricity.
