Thanks for all your replies much appreciated, the reason behind this is we have no gas to property cut of outside 2 years ago empty property, to get it reinstated Had quotes fron gas board and other people cheapest one was £3450 plus vat to £5600 plus vat
Wow, what a rip. My property had never had a gas supply up until about 6 months ago, putting one in involved running a new pipe from the street main and installing the meter. Total cost was just over £600.
at this stage just want electric boiler in as i have 12 rads four which are 1200x600 ds the rest are mostly 1000x600 singles hot water is to be run off immersion any way just need to know if a 14kw boiler will cope or the next one up is 24kw which needs three phase according to brochure With thanks brian
If you really want to go that route then it's your choice, but if it must be electric then I would seriously recommend you consider an air source heat pump. Although not quite as effective as ground source, it will be a LOT cheaper to run than an electric boiler. In fact, there's one on eBay
here going for under £1000 at the moment, so even the initial costs can be cheaper too. It even includes a hot water tank!
However, you would need to ensure that your radiators are properly sized, as if they could only just cope with the water from a gas boiler then they will be undersized for use with a heat pump. This is because the water flow temperatures from a heat pump are lower than that from a typical boiler, hence why they are usually coupled with underfloor heating.
In terms of working out the heat loading of your house, nobody can answer that without knowing room sizes and the amount (and type) of insulation. I suggest you buy yourself a 3kW fan heater, put it in your rooms one by one and see how long (if it all) it takes to get the room up to temperature. You can then use this as a very rough guide as to the output you require from the boiler. I realise this doesn't take into account that when the CH is on the rest of the house would be heated around the room, although it makes sense to overestimate a little. In a modern house I suspect 14kW would be enough to cover CH requirements, but in an older house it may leave you cold.
