youll need SWA and you should zig zag it a little to allow it to stretch if required due to ground heave...warning tape aswell as someone else said.
No prob with laying them all in the same trench
marty.
Thanks for that. If the cable is in conduit 750mm below ground, would i still have to use SWA, as the run will be around 35m and need to be either 10mm, or for overkill 16mm, guessing SWA 16mm is going to be very expensive. if it is the case, any suggestions where is the best place to get this.
Alex
There are some corners that shouldn't be cut. You won't be happy having to did it all up if it gets damaged, and in any case, I'm sure the regs require SWA.
