I'm planning on building a garden office in place of the current shed. It will be at the back of the garden, ~ 40 metres from the house, and have a toilet, electric shower and washbasin.
From what I've gathered, for water supply I can use 25mm blue MDPE and this needs to be buried underground. Can I alternatively put it in a conduit and clip it to the fence?
As for waste water, the site is too far from the house so I'll need some kind of pump.
From what I've gathered so far, the most common solutions are:
I like 2. for the cost and versatility. Do I understand correctly that the pipe that comes out of the pump and goes to the sewer can have bends, and it can be either buried or above ground?
What kind and size of tank would work best with this setup?
- A macerator (£200), but since their outlet pipes can only go up and then down and no other bends are allowed, I could only do it overground, e.g. clip it to the fence.
- Macerator (£200), stainless steel dirty water pump with float switch (£100) and tank. Then run a small bore (40mm) pipe from the tank to the sewer.
- Domestic pumping station which comprises a tank and pump (£700) - similar to 2., but more expensive and doesn't have a macerator, so a 65mm pipe would have to be used.
- Domestic pumping station with an integrator macerator (£1800) - basically 2. but "all in one" and therefore more expensive.
