...and the customer.I'm sure that it is usually the case, but it does depend upon the electrician!
Anyone can do anything themselves - a few items need to be notified to building control, but as that involves completing a building notice and paying a fee, you can do that yourself as well if it is required.just wondered if routing the cables myself would fall inside or outside the allowed work I could do.
No such thing in the UK.licensed electrician
What exactly do you mean by that?I will be getting any wiring signed off and completed by a qualified electrician
If it's just for a couple of sockets and a light, you may not need a CU at all.I am not entirely sure of the consumer unit required. Is this a simple 2 way i.e. one for lighting and one for mains ring?
Snipped...
Doing bits yourself and having someone else to do the rest isn't likely to work, as the total cost of this very small installation will already be rather low, and saving a few quid by installing a couple of cables will discourage most/all electricians from even quoting a price for it.
Probably all of the above, but from what I've read work for such electrical will fall under no notice required if carried out by qualified electrician. If done by DIYer then building control will need to be notified.Anyone can do anything themselves - a few items need to be notified to building control, but as that involves completing a building notice and paying a fee, you can do that yourself as well if it is required.
Testing / inspection to confirm it's safe / coimplies with BS7671?
Notification for building control?
Other?
This is not a trivial question - plenty of people have totally incorrect assumptions about electricians can/cannot do, and what the law actually requires.
valid point. Actually more for the speed of getting it done as no one available immediately and I want to install the insulation but can't really until wiring installed.Anyone can do anything themselves - a few items need to be notified to building control, but as that involves completing a building notice and paying a fee, you can do that yourself as well if it is required.
As for saving time - to install a few cables in a stud frame as shown would not take more than a hour or two at most, so how much money do you really expect to be saving?
Appreciate that would be far from ideal, just like knowing all details myself to understand what's involved and what to expect cost wise. Will most likely just get electrician to do all the wiring (apart from SWA which is buried already) then hopefully avoid getting building control in if I've understood the regs properly.Ultimately there are 2 realistic options - either you install this stuff yourself, or you pay someone else to do it for you.
Where I live, I had a similar job done almost as cheaply as the fee the council wanted. I felt/feel able to do the work, and wanted to. The electrician was happy for me to lay out the SWA for him, and adjusted the price accordingly (slightly!).
Not quite - whether work needs to be notified or not does not depend on who does it, but an electrician who is a member of a self-certification scheme such as NICEIC, NAPIT, etc can notify at a much lower cost than an individual householder.no notice required if carried out by qualified electrician. If done by DIYer then building control will need to be notified
No, you don't need to 'ring' the lighting.
You don't need to 'ring' the sockets either.
