Hi i have a class 1 chimney with the stack removed and tiled over on roof,
and the chimney is not good inside and would need a flue liner. The fire place has been striped out all fire bricks and old water back boiler. There
is a marble fire place that we don't want to damage or try to remove.
Now the problem a gas flue box will not go through the hole in fire place, so a linner can't be fitted. To save having to make a big hole in back of chimney to get the flue box in from the back. What i would to do is to fix a plate at bottom of chimney, cement over the plate so chimney is blocked
off so nothing can fall down, us brickwork to make back of fire place smaller, then have a balanced flue gas fire fitted with the flue going out the through the back of chimney. I own the ground at back chimney and
nothing there to get in way of flue and no windows. Is it gas safe legal to
have this done. Please help thanks.
