Wondered if you could help a query.
I have a rented property which has a gas hob with an isolator valve in the unit to the side. A corgi gas man doing landlord certificate has given me a warning "incorrect use of tap connector to hob connection" the valve is a full bore lever valve with yellow handle. This valve is british gas approved and is one of these from screwfix. http://www.screwfix.com/prods/13103/Plumbing/Brassware/Full-Bore-Lever-Ball-Valve-15mm
Your help / advice on whether this isolation valve is ok would be gratefully appreciated.
Tony
Tony
