just sent you a pm
also...
do any of you gentlemen know where there is an image on the world wide web?
once again - thankyou
no.
do you
FAQS...(0's then) 1.000 on the display, the decimal point is always 3 digits from the right.
Measure the usage in 2 minutes, using the rightmost 3 digits. Remember it might go past zero. You'll have an answer like
0.XYZ cubic metres.
Multiply that figure by 321
That's how much you're using, in kW.
So if you've used
0.085 cubic metres in 2 minutes, that's 27.3 kW
0.XYZ cubic metres.
So if you've used
