Is it possible just to change the gas valve solenoid coil, the boiler is a Glowworm economy plus 40 the glowworm part number for gas valve is 800015 gc part number 313 067 think its made by honywell.
So you can test that after replacing the part its working correctly NOT just working?
Im pretty sure i could replace a consumer unit,its only wires isnt it, but could i test it was working safely and correctly? No.
what does the solenoid look like, is it cylinderical about an inch in length and slides onto a shaft with 2 wires attached,
If so then it will not affect the already set gas pressures on the valve or affect the integrity of the gas installation so go ahead and fit it cost about 20 quid
not unless your van runs on fresh air and you time costs you nothing
you could run back and forth and make a clown of your self and in the end the puntter would then discover that you didnt have a clue in the first place
for the sake of common sense and dignity
bite the bullet and get it changed by a corgi or maybe a CAPITA registered installer
Thanks for the sensible advise.
The gas valve is Honeywell V4700E. I can see the soleniod coil is held on by a clip but I`m blowed if I can see how to release it any ideas please.
IT just pushes out to the side. If its that solenoid gone then don`t worry about changing whole valve have done hundreds off these with no need for a complete valve .
fault is boiler main flame goes out after a few mins, coil loses magatism when coil warms up due to flow of electrons, if I use electronic freezer spray on coil I can keep main flame on.
