- Joined
- 2 Dec 2004
- Messages
- 751
- Reaction score
- 8
- Country
Hi all,
Just thinking about the feasibility of this at this stage.
I wasn't sure where best to post this as its electric, gas and potentially brickwork/lintel work all in one.
My electric and gas meters, and consumer unit are in a kitchen cupboard, awkward to access and in the way of a future kitchen remodel.
Here is a picture of them inside the cupboard:
That is an external wall however, a fairly narrow entryway between the two houses. The gas and electric services come in there literally the other side of that wall.
I would like to think about having those meters moved externally in full, into external cabinets.
Because the passageway is fairly narrow, I would prefer to fit inset meter cabinets. My house is a solid wall house, but there is an old window in the vicinity that might provide an already close opening size. The window isn't used and is covered over from the inside by kitchen cupboards at the moment.
So here's what Im thinking.
Use that window opening to house an inset electric meter cabinet.
Directly below it, remove the outer skin of wall and fit an inset gas meter cabinet.
Get the meters moved.
Then obviously it all has to be connected back up internally at which time I'd take the opportunity to lift the consumer unit up close to ceiling level.
Any thoughts on this please would be greatly appreciated.
I was planning to remove that old window and brick it up anyway, so this might be a good use of it.
I'd be looking to put a thick steel flat bar lintel in to the brickwork to support the area above the existing window. Then I'd be free to remove the window and also cut away a new opening below for the inset gas meter cabinet.
It all sounds relatively ok to me, but it would involve multiple trades so not really sure how I would coordinate it all.
And no idea on cost of moving meters.
Appreciate any views.
