I'm assisting a qualified electrician to do a complete house re-wire, by pre-lifting floorboards, chasing walls, etc. (all the grunt work!). I'd like to re-locate the CU, which is low down and difficult to get to under the stair cupboard. The house is an ex-council property, built about 1960. I'd like advice please on: 1. difficulty of running longer tails from the meter in order to shift the CU; and 2. what's typically the easiest route up to the first floor for all the cable runs (ground floor is concrete). I am assuming that pulling through using existing cable will be impossible, and that most of this will be left in situ but dis-connected. Many thanks.
