Hi All, Sorry for the long winded post however looking for a bit of advice and to see if someone can point me in the right direction.
My son has a Glow Worm Micron 50FF in his house. Boiler has been fine and I recon it was fitted when the house was first built 13 years ago.
Two weeks ago he came home to no heating/hot water. Boiler was dead and wouldn't fire up, there was no lights showing on the boiler even after he tried to reset this however the fan was running constantly until the electricity to the boiler was turned off.
He has home emergency(not BG) through an insurance scheme. They called out an engineer who said it was a diverter valve. He got the boiler running and came the next day and fitted a new motorised head. The next day it cut out again. The engineer returned had a look at the programmer/timer and said he would submit report to Insurance company. They phoned and said the engineer stated there is a wire missing from the programmer. They were informed boiler had been fine for years so doubt a wire had just suddenly disappeared.
They send another engineer who states it's the boiler circuit board. Company stated £280 for board plus fitting.
They then send glow worm engineer under the fixed price repair as they thought this would be a better option. He diagnosed an air pressure switch and managed to get the boiler running. Part was not in stock and would take 3 days to get as it was over the weekend.
The next day the boiler cut out again I went and had a look at it as he stated it was the APS was the the problem. I turned off the electricity supply, removed the front case(not combustion case cover) the APS is at the top of the boiler, disconnected a clear plastic tube which runs to the fan and also branches to the top of the boiler and terminated in a black rubber stopper. I blew lightly into this which activated a micro switch in the APS. Put it all back together switched on electricity and the boiler started and ran without problem.
The glow worm engineer attended a few days later and fitted an new APS and tubing then left. An hour later boiler was off again. My son phoned Glow Worm who contacted the engineer he now states it will probably need a new circuit board and fan however didn't find any issues earlier. Glow worm no longer stock these parts because of the age of the boiler however did give me the part numbers which can be purchased online. I went over and blew through the tube to the APS activated the micro switch and got it working again. Glow Worm refunded money to Insurance company and they couldn't fix it.
So 3 engineers visited and different parts identified. Insurance only covers up to £150 in parts and call out plus 3 hours labour if the problem is fixed.
To cut a long story short what could the problem be if blowing through the tube to the APS gets the boiler working. Is it likely to be the fan which, continues to run when the boiler is not working until switched off at the mains, or the circuit board.
Thanks for taking the time to read this and all help appreciated.
