Starret, Bosch, but I think you'll struggle whatever you use. I think some of the guys who visit here recommend chain drilling. Either way cast is a b***h.
been watching this post myself for some idea's, i have never been able to cut a hole into a cast pipe, i tried once and failed! so now i just replace in plastic
Use a starret hole saw and use a drill with a low spin speed. Get some cutting oil and a squirt can and get someone to keep the drill cool by giving it a squirt now and again, take your time and you'll get thru it.
I found absolutely no problem drilling a cast flue pipe using a lennox saw and after grinding away the vitreous enamel. I used a DeWalt on it's lowest speed and just kept the speed down. No lubricant either. No problem.
I see what you mean about low speed cutting, keep the heat down etc.
Regarding low speed cutting, I bet it wouldn't take much too crack a bit of the cast off if the drill were to jam on a higher speed..
