Granny charger socket - new fuse box and 1400+vat?
Naa most people do, PEN faults are rare.
for a PEN fault to occur both the neutral and earth would have needed to come loose (or severed) but the Live still intact and connected ?
(never heard of a pen fault)!
The neutral is lost elsewhere in the road or wherever, it doesnt matter too much inside the house as everything should be bonded its more dangerous outside which could make the car live, but its rare.
Im also not sure if the supplied charger would have some protection for this?
The neutral and earth are the same conductor outside the property, so it's a single break, usually at a joint that has corroded away.
CNE = combined neutral and earth.
PEN = protective earth neutral.
Different names for the same thing. BS7671 favours PEN even though such things are not permitted in consumers installation. Distribution where such things are actually used is CNE.
Cable damage that totally disconnects the CNE and leaves the other conductor intact is possible but very unlikely.
When it's broken, conductive parts which are connected to the main earth terminal of the installation can have a voltage on them which is significantly more than the actual Earth people could be standing on outside.
The most dangerous item in this scenario is the outside water tap installed with metal piping, as that is connected to the main earth terminal via bonding and it is something which people can grab onto. The ground below it is likely to be wet, further increasing the danger.
Other things such as metal cased outside lights are less of a problem, as although the casings can have a dangerous voltage, they are not normally touched and even if they are, they are not typically something which you can grab and hold onto.
Electric vehicles plugged in and charging could be a problem as the metal frame of the vehicle is connected to the earth pin on the charge connector, and therefore to the main earth terminal of the installation. However as previously stated, the vast majority of the exterior of a modern vehicle is not bare exposed metal and there are very few parts to grab onto and hold other than door handles, and they are usually plastic.
Do the supplied chargers have any sort of pen fault detection installed?
