Granny charger socket - new fuse box and 1400+vat?
22 Dec 2009
Surrey
Exasperated. I don’t want a full ev charger as i have one at work and it’s only a hybrid. Have got a granny charger and thought it would be sensible to add an ev rated socket outside my garage near the CU. For now I’m charging at 6a off an indoor socket. It’s limited to 10a anyway.
Anyway, I’ve been quoted 1400+vat as they’re saying my ten year old CU isn’t compliant as the rcds are type AC so i need a type A RCD on a dedicated ev fuse box.
For that money, I’m seeing adverts for EV chargers fitted for half the price? I’m in Surrey near Croydon so probably the city premium.
This all seems massive overkill for a granny charger. What do others do and is this price reasonable? I really thought i could just put in a tougher socket off a spur or new breaker and it would do the job.
Can you not just add a Type A RCBO in that consumer unit and a 6mm² cable to a conventional outdoor socket?
The AC RCDs can't be used for any new items.
They could easily be changed to Type A.
No dedicated piece is required for an outdoor socket.
I just fitted a charger for a mate with a 40A RCBO & a spike arrester into a tethered charger that he supplied. Yes, this was on the other side of a wall to the main intake & yes, mate's rates, but £220 inc. materials.
A charger would be a more sensible option in my opinion especially for ease of use and future proofing. Do it properly. Granny chargers aren’t meant for permanent use.
I have a socket on the side of my shed, my son would use when he visits, no loss of PEN detection, on it's own type A RCBO for just the shed, and for the once in a blue moon he visits, not really a problem. I do have an earth rod, so voltage with loss of PEN is going to be less to true earth than without it.
But for use every week, the granny charger is not really the way to go, the cost to fit loss of PEN detection means unless your home is on a TT supply there is little gain having 13 amp to 32 amp, money wise, and the 32 amp is a better system in the main.
So in general the 13 amp socket option is for charging either inside a garage, or with a TT supply.
'loss of PEN' devices don't detect the thing they claim to, the benefits of such things are questionable, and the cost of them as standalone devices is excessive.
I bow to your knowledge on such things, I have watched your YouTube tests, etc.
The loss of PEN in theory could mean dangerous voltages, but in the UK, I have only found loss of PEN once, caused by road works, and I was called as the guys earth wire was melting, where his amateur radio's earth was connected to the DNO earth, and the insulation was dripping off the earth wire, until the wire melted, by that time he had turns of all power, but turning off the isolator did not isolate the earth.
Now working in Algeria came across it many times, but only one in the UK.
However it seems with the uneven load caused by people installing heat pumps, batteries, solar panels, and EV charging, the cases of loss of PEN are increasing.
But out doors most equipment is class II, and although loss of PEN can damage equipment, within the equal potential zone of the house, it is not really a danger to people.
Why EVs were ever made class I, I really don't know, but to have a large lump of metal which is easy to touch, at a different potential to the ground, if over 25 volts is clearly a problem, I was told 25 volts can kill a cow, clearly it has four legs, but anywhere that the public and reach, we really should be looking at under 25 volts, although the rules say with AC 50 volts, so it seems that is considered safe for a biped?
But in the main, be it loss of PEN or a RCD, we hope no one touching at the point the fault happens, so we have time on our side, so it has tripped before we touch anything.
But I note my solar with over or under voltage disconnects, but then will auto reconnect, I would guess same with loss of PEN, so unless a three phase supply, where we compare voltages, yes I see a problem, as some loss of PEN detection will auto reconnect as it is simply looking at the line voltage.
However, it is a risk assessment, and the question is as always, on a forum can we assess the risk? I would prefer to tell someone not to do something, to reading in the papers how there has been another death, which could be as a result of not raising the issue on a forum, if issue is raised then ignored that's OK, but we must tell people there is an issue, even if it is ignored.
Assuming a TN-C-S supply likely you will need a loss of PEN disconnection unit View attachment 427641the net result is fitting a 32 amp or 10 amp charging unit are very close to the same price when all rules are followed.
I think this is what I’m having trouble with. I thought one route would be much simpler but it seems not with the regs. Thanks.
