Grant Combi 90B3 HELP
Status
Not open for further replies.
Terry wanna talk me through exactly what i am meant to do starting from if i should even have the boiler powered up to begin with before i hit the reset button and loosen the bolt ?
Nup, it's you that needs the help, but your stattaco posting doesn't help. You'll find Nixt is quite a knowledgeable guy, so it might be worth bearing that in mind.
The G5 burners are tedious, though not difficult. however looking at your postings, it looks like it would be a good plan to get someone in. You can ring Grants for a list of names who will know their combies. Not every tech likes doing, or even does combies.
I've given plenty of burner advice on here, mostly to those who let you fit a post in edgeways 28.
I am sure you have when you take a break from spamming the forum with other tripe.
No need to get defensive with me Nixt i am only passing through, its your home not mine.
Maybe, but at this rate, in the next 5 minutes you'll make Agile, g4u, Chris R and the rest seem like strangers.
Joking aside, I sincerely hope that your problem is diagnosed and cured...... Oh and maybe your burner can be fixed as well.
Status
