Gravel driveway edging and issues
1 Oct 2018
Hi
First post, hoping you can help.
We moved into a house recently where the driveway has been bodged, the old concrete was removed but they have just tipped gravel on the earth/rubble, so it is one stone deep by the door and about a foot near the kerb!
Anyway. So, we will redo the driveway in time but not now. Now I need a temporary fix.
The council have agreed to drop the kerb under the condition that we:
-install boundary edging to footway level
-install system to prevent gravel spreading
I presume the first is edging stones that I can dig and concrete in?
However, on the second, any ideas how I can do a short term fix that doesn't involve a complete overhaul (that is to come but not this year!)
Thanks in advance!
I assume they mean a 1m wide rumble strip or similar at the threshold of your driveway to prevent the gravel migrating onto the footpath.
People foolishly believe that gravel will be maintenance free. It isn't. The gravel will migrate as vehicle tyres spread it to the unused areas. Weeds will grow where there is least traffic and will set/germinate from above.
The edging stones is the very same "system" to stop the gravel spreading.
Councils are asking for a (certain width) buffer between the gravel and the footpath. We have done a few. Gravel still finds its way across though. Must be those pesky tyre treads.
Can they? Under what powers?
The only way I can think of the council being able to dictate what a homeowner does with their drive, is as a condition on a full planning permission for the building and landscaping. Highways Dept (dropped kerb) certainly can't insist on anything.
Asking is not the same as insisting.
The council can insist that you don't make the footpath more hazardous.
The Bullnose edgings, not the kerbs like there are at the side of the road.
With at least 100mm of concrete below and concrete either side and sloped up, but kept lower than the top to allow for whatever paving there is.
As per Woody - bull nose concrete edgings. You need these in place as your demarcation buffer, irrespective of whether you add a rumble strip along side. They also need to be on your side of the property line. This is so that highways can dig up the footpath and not bother your drive.
