I was drilling holes in kitchen cabinet. The drill slipped and there's a graze on a water pipe(15mm copper pipe). The grace caused a sharp bit on pipe however it's not leaking and I wanted to know if I should just leave it or do anything
....turn it in FFS.Rub it down so you smooth out the rough spots, put some solder on it, then wipe a piece of moleskin over it.
So you've wiped underhand/rolled/knuckle/branch joints without the use of plumbers black??No idea what plumbers black is, but I do have a piece of moleskin (somewhere) that I used to wipe lead joints with - God, that was years ago.
