Guardtec 350 alarm
12 Jul 2019
hi my guardtec 350 house alarm control panel goes off when the alarm isn't set - any ideas why pls
Replace battery ASAP.
Screwfix is quickest place to get one.
How old is the old battery ? may have damaged a resistor on pcb ?
Sparky marka ? - classic ??
Handymanjo - battery where please ? Sorry I have no idea
Battery is in the control panel
Should be 2.1ah battery which you can purchase from screwfix the DIY chain.
Search screwfix in your area.
Classic ! ...they don’t print a icon or a word at the side of every led on on the panel for nothing ....
Sparkymark there are no words on the display panel just numbers and like I said they are all flashing
Thankyou we keep doing this / had to do the reset 5 times last night and about 10 times since 7 this morning - don't understand why it's doing it
You need to replace the battery
To stop open control panel and remove battery. Reset with code.
Go and get replacement battery and re fit battery.
It will keep setting the alarm off until you remove or replace battery.
You will need to install a battery otherwise every time you have a power cut the alarm will activate
