I need to replace the backup battery for a Guardtec 595 house alarm but can't find anywhere which one I need. Also any idea where I can get one ASAP from?
Technical Specifications GT595 Large Metal GT595 Polycarbonate/Metal
Voltage Input 230 VAC 230 VAC
Max Loop Resistance 2K (not with EOL) 2K (not with EOL)
Battery Sizes (Ah) 1.2 / 2.0 / 3.0 / 7.0 / 17.0 1.2 / 2.0 / 3.0 / 7.0
Quiescent current 150mA @ 12VDC 150mA @ 12VDC
Power Supply 2 Amp 1.2 Amp
Dimensions (HxWxD) 418x379x98mm 235x270x65mm
357x334x87mm (small Metal)
From this www.britishsecuritytechnologies.com/...alarm/Gardtec-595-Control-panel+family.pdf page it seems the installer has to select battery size according to load, I think you will find most are fitted with 7 Ah it seems to be a standard size for alarms.
