Guttering rubber seal replacement?
3 Aug 2014
Down
The rubber bit that joins two pieces has gone and now there is a gap and have leaky guttering. Its on the garage.
Is it possible to get a new seal etc? Whats best way to fix this ?
Thanks in advance!
Doubt you will get spare seals but if you can ID the maker just buy a basic fitting like a connector and swap the seal.
Unclip the joint, clean the mating faces and the rubber seal, and refit. It might not work but you've nothing to lose. Do it on a hot day as the plastic clips are prone to breaking, especially in the cold.
