Hanging 12KG Mirror Onto Platerboard No Studs
23 Aug 2013
South
I need to hang a 12Kg mirror onto plasterboard, no studs behind and can't move it elsewhere.
Do I use
http://www.toolstation.com/shop/Scr...elf+Drill+Driva+PD100+Metal/d90/sd1930/p75893
or something else on here
http://www.toolstation.com/shop/Screws+Fixings/Cavity+Fixings/d90/sd1930
Those Redidrivas look good and diynot says there great, but UHMan... says there not good for supporting heavy stuff.
So confused, looks like the strap toggles are brill, but need to do it tomorrow ideally, rather than ebay them
Sorry, I wrote something which I then deleted. I should have use the word "deleted" But now I'm thinking that my original deleted advice might be useful after all. Sorry for the confusion. I was in a rush!
Try these: http://www.screwfix.com/c/screws-nails-fixings/spring-toggle/cat840118
Use the smallest ones possible. They require a large hole to be drilled, much larger then the thread size would suggest.
