I'm replacing an existing light with a low voltage cable system. The transformer supplied with the lights is supplied with a 3amp fused plug.
Clearly I would prefer this to run off the existing lighting circuit.
I was proposing therefore to cut off the plug and wire into a 3amp fused connection unit which would replacing the existing circuit connection for the current light.
My question is therefore - is what I'm proposing logically sound and safe from a building regs point of view? or is my only alternative to find (or in this case add) a socket off the ring main into which the transformers plug can be connected?
Many thanks
Many thanks
