Hardcore for greenhouse base? (Moved from Projects)
6 Apr 2014
Manchester
I've cleared an area of garden to build a 10'x12' base for a 6'x8' greenhouse. About half of the cleared area has a reasonably level layer of brick, which was the floor of the shed that was there previously. The rest is compacted soil. I'm thinking of laying concrete slabs on a dry mix of sand and cement. Will I be able to lay the sand and cement directly onto what is there already or would I be better adding a layer of hardcore first? Either way, what depth should the sand and cement be?
Any help would be much appreciated.
Cheers
BlueGirl
Thanks for that, it's really useful. Still unsure whether I need to bother using any sort of sub-base is required. I'm thinking I can maybe get away without it provided the bedding layer is a decent depth. Anyone see any issue with the fact that half the area is brick and the other is just compacted soil?
BlueGirl
I would be relatively happy to go ahead and lay straight onto the ground assuming your using a 50mm bed of 6:1 or stronger and as long as its been compacted. Personally i always prefer to throw down even an inch of hardcore as trying to compact bare soil doesnt really work, your better off trying to ram hardcore/ gravel into it with a vibrating plate to achieve compaction.
If possible try and have a joint in the paving where the base material changes as if you don't redo the whole thing you will get a little settlement in the medium-long term as the two sub-bases settle differently which may crack the paving or if not will certainly crack the joints. (mainly superficial aesthetic crack)
