I'm building a summerhouse, roughly 5.5m x 5.2m. I've been told this will need 100/150mm Sub base, with 100/150mm concrete on top. This will be in the form of a slab.
I'm planning on getting the concrete pumped in, as I'm about 50meters away from where the concrete truck will be.
I have about a tonne of bricks in the garden, which I can smash up. I also have around 2 tonnes of gravel, which is around 20mm in size. I will need to order a few tonnes of Type 1 - what do you think is the best way to use this hardcore altogether?
Ideally I'd like to use up the bricks and as much gravel as I could. I don't want to have any voids in the sub base though. Could I throw in a few tonnes of Type 1, mixed with the brick and gravel? Would this compact ok?
Would I be better putting the brick down first, then compacting with a layer of type 1, then gravel mixed with type 1?
My ideal outcome, would be to use as much Gravel & Brick as poss.
Ideas welcome, thanks
