- Joined
- 11 Jan 2004
- Messages
- 46,903
- Reaction score
- 3,995
- Country
I lifted a board in the bathroom. Unfortunately, a pipe was glued, yes glued to the underside of it....
Now the pipe is sitting at a 45 degree angle to horizontal, sporting a nasty "I'm going to leak any minute" kink.
It's the cold pipe, so I can easily isolate at the main cock. However, for a spark of 25 years, with no plumbing experience whatsoever, do you think you I could cut and cap off the pipe without flooding the place?
If so, what parts and materials am I best endowing myself with?
Could I get away with just buying a pipe cutter and a plastic push fit stop end?
The hot is OK, but would like to do away with a piece sticking up above floorboard level.
How do you isolate the hot?
Is pushfit reliable on hot pipes or do you need a compression fitting?
I am donning the helmet now, as I can see it coming as I type.......
Thanks!!
EDIT: Uh-oh, I've just had a nasty thought. What if it's tank fed cold? Is that likely, or will it be mains? It's the old feed to the basin, which is tapped off the pipe feeding the cistern & the bath too.
Thanks!!
