Hey everyone, oil was running low on thursday so got 500litres on Friday, it may have run out on friday morning before it was refilled but I cant be sure, since then my heating has not been working correctly.
I have to reset the boiler and then it will fire up and all the radiators in the house will heat up and then after 30 minutes or so the boiler will cut off and I have to press the reset on the boiler, I have avoided doing this just incase I am causing damage.
I have bled all the radiators and pump just incase.
I also bled the boiler of oil but not sure if I did this correctly or not, there was a small brass coloured nut above where the oil supply enters which I loosened and then oil started coming out at pressure, then I tightened it again as I assumed there was no air, I only did this for a few seconds.
If anyone could shed any lights on this it would be appreciated, if you need any more information about my boiler etc just let me know.
David
David
