Hi, I’m trying to replace the transmission belt on a Hayter H1842 lawn tractor (I think this is the same as a Countax 600H) but having problems fitting new belt - see picture.
I don’t see how it is possible to get the belt past the (green) metal bar that’s just to the right of the main clutch pulley (curved bar at bottom of attached pic). Unfortunately, the belt I’m replacing was broken so didn’t remove - so, cant just reverse that procedure. I’m assuming I don’t need to remove everything before it on the clutch side as this would seem like an unusually complicated process to replace a transmission belt. I therefore assume I missing something with this that makes it relatively easy?!
