Well, you had jumped ahead a bit as I said. Not sure where you are now with clock on or of so suggest you do as above. Have a look at the boiler because if you turned the power off while boiler was running it may have gone out on overheat. This is what the pump over run prevents. What boiler is it but have a look for a re-set button anywaySuggest you go back to putting the wires in to clock but under screws, turn cyl stat to normal position, turn room stat up, heating should now run & indicator in H position. Give it 10 minutes before you decide whether this is the case or not. Turn room stat down & heating should go off but again, don't be hasty.
