i have installed the following system oil firedwarmflow rd3 boiler celsia pump,switchmaster805, 2 motorised valves,hot water cylinder with stat.The boiler is about 5 years old but the rest of the installation could be up to 20 years. no room stats. Recently experiencing problems trying to switch off boiler by using the buttons on the switchmaster although the motorised valves on hot water and heating respond to the timer part of the switchmaster, however the pump continues to run 24/7.When the timer and the switches are put in the off mode any adjustment to the boiler thermostat will instantly fire up the boiler .Any ideas?
