Desperate for some help here, I stupidly went cheap on the boiler when I rennovated my house and bought a Heatline Vizo 24, I have had a few issues with it - mainly the central heating.
Its been cold recently so I decided to turn on the heating for the first time since earlier in the year but guess what - its not working and i've not seen this fault before. When I turn on the heating the boiler fires up as usual but only runs for about a minute then stops, there is a sort of whirring noise that is present when the boiler is running - i do not think it is unusual. After about 5 minutes the boiler fires up again but does exactly the same, this process continues while the heating is on. There are no error lights displayed, I get perfectly good hot water from the taps, the only thing I think is unusual is the water temperature lights seem to go up faster than I remember but they do not go to the max but stay between 70-90%. The water pressure is normal.
I have recently taken off one radiator to decorate, it is back on now (I thought it might be the problem but putting it back on made no difference) I have been around the house and checked that everything is open and all the radiators are bled.
Its really bugging me this Heatline Vizo 24 and if I had any advice for anyone considering buying one it would be - don't do it! it'll only cost you in the long run!
I'm cold and would love some help - a new boiler is out of the question as i'm layed off work as of tomorrow so hopefully its an easy fix.
