putting in a new oil pump once i set the oil pressure how do i adjust the air to give me the correct CO2 of 10.5,thanks for your help
burning fossil fuels. the more efficient burn the less CO in PPM yes?
In an ideal world stoichiometric combustion would be the most efficient burn , due to inaccuracies in the metering of fuel/air excess air has to be introduced into the combustion process (15/20%) , this makes for a fuel lean burn to which burner efficiency is impaired.
Air is done by adjusting the damper setting dial. Do you have means to measure the CO2?
