I'm installing a ceramic Reginox RL304CW sink on top of a 40mm laminate worktop.
The sink is quite heavy. I'm wondering if the worktop will be strong enough to hold the sink as it goes near the corner. What are the minimum distances from the sides of the worktop as I've got it directly from Reginox and they did not supply any instructions.
Also do you use the same sink brackets for tightening that you use with the stainless steel ones ?
Thanks...
Thanks...
