My local friendly installer installed a Glow Worm Ultracom boiler some time ago and it's never been quite right, in fact it ended up quite wrong.
This was a boiler replacement and as part of the work he also installed TRVs, which I understand are now required. What I didn't know then was that there should have also been an automatic bypass valve installed. There wasn't. The installation instructions say there should be one but he has ticked the check list to say it was not required. I presume there should be one.
The installation instructions specify that the pump should be wired to a connection within the boiler. It wasn't, it went to an external junction box. I presume that the pump connection inside the boiler provided pump overrun but there is no statement to that effect within the instructions. Could anyone confirm if this boiler connection is pump overrun.
I know it's not a lot of use having overrun without a bypass but just want to check. The continuous entry of air into the system and radiators failing to heat after 18 months because of sludge didn't seem to convince the installer that anything was wrong.
He also managed to give us a gas leak by damaging the manometer connection on the gas meter. A really competent gas safe engineer.
