- Joined
- 1 Sep 2006
- Messages
- 22
- Reaction score
- 0
- Country
Hi
I'm having an absolute nightmare with my kitchen light. When we moved into the house there was a halogen fitting in the kitchen with only one bulb in it, but it worked fine. However.... when we replaced the other three missing bulbs the light stopped working. Since then we have done the following to try and get it working:
Replaced the fitting with a normal pendant fitting.
Replaced the switch.
Tested the circuit with a multimeter.
The result of the above is that all are wired in correctly as far as I can tell having checked every diagram I can find. When testing with a multimeter on the pendant I get a circuit between the live and the loop, but no circuit between the neutral and the loop. I have no idea if this is right as the fitting upstairs seems to produce a circuit for both.
Any ideas on the problem?!?
Thanks for any help you can offer!
Lucy
Lucy
