Help !!! my valliant ecotec plus 418 boiler packed up
3 Mar 2020
Leicestershire
No hot water nor heat.
First it made louder noise wen firing up like bubbling but then once up n running noise stop n worked fine did that for about week then it just stopped
It still fires up but cuts strate out
Intially no codes
Then Code f22
Then code 72
Now code 23 grrrrr
No pressure gauge on this model , I cannot locate filling loop n even if i could how would i know how much with no gauge .
Secondly i was thinkin air in the pump n been tryin n to unscrew the bleed screw on pump but it is firmly stuck
The pump gets hot but pipe leading off from pump get just slightly warm at the start the rest of pipe is cold .
Please any advice wud b great
There should be a gauge on the front, is it the blue lit digital type? If yes, then press a button to wake it up, and look on the right hand side of the screen, there’s a digital gauge there, usually 2 sets of dotted lines, pressure should be between these. Secondly do you have a cylinder? If yes the filling loop could be located there.
Seized pump - perhaps that was the noise you were hearing? Try to get that screw out and see if you can turn it with a screwdriver.
Hi thanks for replies
I have water in the tank in the loft
I have a digotal reading of pressure which says 1 bar bit if i needed to put more in u cant see a dial like u can on other boilers
I tried for ages to get that bleed screw out of my pump but it wont budge at all i tried with various screwdrivers n it wont move at all .
I will post some pics of my set up in a min so u can see what type it is .
As others have said, the pump could be siezed/stuck, especially if the pipe from it is only warm.
Ok thanks
Yes the pipe right next to pump is warm but nowhere else
Pump is definitley louder now
The bleed screw is certainly stuck it wont budge at all
I got my bro to try n turn it too n it truly stuck .
Anyone any udeas of ways to free the bleed screw
Which way are you turning it? Are you using a flat bladed screwdriver?
That lever valve should be open, I'd guess you've starved your system of water. You shouldn't have the casing off your boiler - it forms the safety room seal and should only be removed and refitted by a Gas Safe Registered engineer
As other have said you need to open this valve and leave it open do not close it again , 1/4 turn to open it
