I have been laying Sensa laminate flooring in our recently purchased Victorian terraced house on the ground floor. The ground floor is split into two levels which are separated by a door frame. Basically the hallway and living/dining room are all one level. At the end of the hallway is a doorframe that leads to the kitchen which is about 6 inches lower that the hallway.
Currently there is a piece of old floorboard which slightly juts out which is the current nose of the step. I need to replace this board (as it is broken) and then lay the laminate on top in the hallway up to the edge of this board (allowing the usual expansion gap).
I had hoped to find a stair nosing piece that I could use to cleanly finish the step but Sensa don't make anything useful. I've seen a bunch of different nose profiles but I'm not really sure of what sort is best to use, particularly to provide a reasonable match to the California Rosewood flooring I'm using. Pergo do a good nose section but obviously matching colours would be difficult.
Here is a photo of the door/step as it was before we purchased the house. Both levels are going to be laminate.
Has anyone got any advice that would help me with solving this?
