- Joined
- 6 Mar 2008
- Messages
- 7
- Reaction score
- 0
- Country
Hi, I'm new to this forum so please point me in the right direction. I never do DIY other than change a plug, fuse or lightbulb... (yes, I'm female) so I'd really appreciate your help.
The under cupboard lighting in one unit of my kitchen is not working (the rest are so there's no problem with the system). It is not a bust bulb as the same bulb happily works in the other unit when I tested it. I therefore think it's just a loose wire connection and the unit played up for about a month and a 'gentle' tap or knock would get the unit to light up, but now that doesn't even work.
I've unscrewed the unit out of the wall best I can (but only got a couple of inches of wire/lead) to take a look as I knew this wasn't too adventurous (or dangerous). All looks to be in place but at the end of the day I can't see how I can check the actual ends of the two wires which are held firm in a little white plastic housing (about 12mm x 9mm) where they would normally meet with the metal ends of the halogen light bulb were it inserted.
I'm thinking perhaps one of the wires isn't fully in place here, but I can't really see what's going on and there aren't any screws or obvious way to remove this housing - other than perhaps just trying to pull it off. There are two tiny 'windows' (like 1 or 2mm) on both sides which might just show the wires passing through as I can just about turn the unit to see some silver metal colour in there. Or is this some release mechanism if I were to somehow press down on the metal, would it slide the unit out?
I admit I am a clueless housewife... but it seems ridiculous to call out an electrician to fix what I'm sure is a very simple, two-minute job.
Can anyone help? Thanks...
