Help with cordless drills
11 Nov 2004
I am a bit confused by the ratings of some drills. I need a cordless drill, and was considering either a Bosch PSB 750 RES (rated at 700W) or a Bosch PSB 14.4VE2 (rated at 14v).
Why is one rated in Volts and the other in Watts? Which is best??!
Thanks!
Matt
heeelllooo mat 80
the mains one off course is 230v by 700w input power if its variable speed its likely to be about 550w output
on battery they normaly quote the voltage and somtimes the wattage
in general higher the battery volts higher the output with a 30% or40% reduction for cheeper makes
look at nm rating higher the more tork although this is often achived by lower gearing hence slower working on lighter work
I know the PSB model is a hammer drill - does that make it likely that its more "effective" than the other one, regardless of power?
General sort of use, I might want to drill masonary but not very often. Plaster and wood mainly I guess - mostly interior.
I know cordless ones arent as good as corded ones, but one thing I do want to do is convert all the sockets/light switches from surface-mounted to flush... which I guess means I'll need to disconnect the power in order to drill into the plaster...
The most important thing is the combination of volts and the amphours of the battery this gives the energy capacity.
Which can be used to either give higher torque or more battery life or a combinbation of the two.
To work out the watthours multiply your voltage by the amphour capacity of your drill.
So a 15.4 volt drill with a 3.5amphour battery will store more energy than a 18volt one with 2.6amphour battery.
The heaviers the drilling you want to do the higher the watt hours you need also the longer you will be able to go between charging for easier tasks.
GET A PANASONIC :) :) :)
for your purposes a decent battery drill is as good as a mains if you get a decent make and decent voltage
vor example i have a dewalt 18v drill [7 years old will drill through any thing]i also have a ryobi 18v which i think might serve your purpose i classify it as diy light trade £90 argos
Well I can get Bosch at a heavy discount due to the company I work for :). I can get a PSB 700 RES for £50 or £22 refurbished (basically unused returned items or damaged packaging).
On that basis, can anyone recommend a Bosch model that would suit my needs the best?
Thanks again for all the replies.
should be fine
ive got a green 700w bosch and i use it for masonary[but not lintles :wink: ] green are basicly diy light trade blue is the big boys stuff :wink:
I just bought a Bosch 14.4V 'professional' model (blue with aluminium 'nose' and red details)
I cant remember the model number but it is a really great piece of kit. I have drilled through everything (not specifically lintels but concrete) and I really cant fault it.
