No, that's much the same as your previous one, and also a weld failure! I can see I'm going to have to draw something, but will have to do so later tonight.Any closer
OK - as you say, it's not that much different from the previous one (except it's not split), but I wondered if it was perhaps moving in the right direction. The problem, and what is rather surprising, is that if one does Google Image searches, most of what one finds looks like one or other of the pics I've posted, invariably described as a 'satisfactory crimp'!No, that's much the same as your previous one, and also a weld failure! I can see I'm going to have to draw something, but will have to do so later tonight.Any closer
Yes, I agree with all of that. What I'm pondering is what either of those piccies (or any others like them) would have looked like had it been a solid conductor that had been crimped.Yes, I'm probably being too picky. Both those samples would be satisfactory electrically, and would probably pass a pull test. To be honest I suspect that a cold weld will be made at various points along the compressed part of the conductor so a section at any point won't show a full cold weld. The same principle was used in wire-wrap joints on early mainframe computers where there were 20 points of contact per joint so enough were likely to be good.
Why would you want one side to be crimped less tightly than the other?
Wouldn't that look much like the second pic I posted if it were sectioned through the indent?EFL, yes, thanks, that's the sort of thing I meant. Failed according to BS 7609 though!
I don't think so. I think the example in your picture is more 'folded in' along the seam for a certain distance rather than 'punched' as is mine.Wouldn't that look much like the second pic I posted if it were sectioned through the indent?.
That's true, but the shape one sees in section is obviously a function of the size and shape of the 'blunt spike' producing the indent - so I thought that something conceptually similar to that which produced yours may have result in the picture.I don't think so. I think the example in your picture is more 'folded in' along the seam for a certain distance rather than 'punched' as is mine.
Good point - particularly in relation to the first pic I posted; maybe that's what it was. As for the force needed, I would imagine that factory-fitted ones are probably produced by a serious press, not a hand tool.I haven't. ..... What I was thinking of - your picture - is more prevalent on small wires which come prefitted with the connector; as in car wiring where the crimp ends up looking like two adjacent tubes. I imagine this would take a lot of force and precision.
the TLC ratchet crimpers which BAS frequently promotes.
Use a crimper LIKE this:
Use a crimper LIKE this:the TLC ratchet crimpers which BAS frequently promotes.
http://www.tlc-direct.co.uk/Images/Products/size_3/DVDHCR15.JPG[/QUOTE]
Yep, that's the one.
Kind Regards, John.
