Chalet bungalow - two floors - loft space positioned not above the first floor but
on the same level.
I'm installing a new bathroom in a room that wasn't a bathroom.
I want to use low voltage lighting, with individual (dimmable) transformers.
At present there is one pendant light/rose.
I will need either 7 or possibly 8 - 50 watt dichroic halogen bulbs to cover 8m2.
MY QUESTIONS
Does the following wiring sound okay?
From the ceiling rose (now inside the loft area) connect to junction box ONE
then daisy chain to junction box TWO.
From the two junction boxes run 1.5 cable to individual transformers, using
one junction box for 4 LV lights.
Or can I get away with just one junction box?
Also, I should know the answer to the following but I can't get my brain in gear;
. . . . . will the one pendent/ceiling rose support eight 50 watt bulbs?
. . . . . with the electric bill in mind - will eight 50 watt bulbs use as much power as
400 watts incandescent household bayonet bulbs?
Just two more questions;
As I understand it, if I use "dichroic" sealed units I have to install "firehoods".
Once the firehoods have been installed can I lay loft insulation over the top of these?
If not, what is the suggested 'open space' above and around each light fitting?
Many thanks in advance.
Stephen
