Hi. About 10 years ago I had British gas install their Remote Heating Control hub, receiver and wireless thermostat. All worked very nicely and later they brought out the Hive app so I could use it on the phone. Now they brought out a new Hive and my old system has been discontinued and no longer works. I've bought a new dual Hive receiver, hub and thermostat kit and tried to install it. The old receiver back box is exactly the same as the new receiver so I just swapped the receiver but the wiring is wrong.
I can only get heating by pressing the hot water boost button and this brings on the heating for half an hour. My old remote heating only controlled the heating. The hot water is controlled by my old wall programmer time switch.
I'm hoping this is quite a common problem caused by the Hive switch over and that someone in the forum might have found an easy wiring solution.
I've added a few photos to show the old back box wiring (with a link as suggested for having the old programmer permanently on for heating) and the new hive wiring diagram. I only want the new hive to control the heating and not the hot water. Any advice gratefully received.
Thanks in advance for your help.
