thanx i am now beginning to understand what you mean...do I need a professional to adjust the pressure if this is the case?
If removing the heacd has stopped the problem, then you could try a few things first,
If the boiler will allow it ( read the instruction ) try turning the pump speed down a notch, and try it with the head back on.
Again if the boiler will allow it you could change the pump to an grundfos Alpha pump, (but I don't think you can)
Trace the towel rail back and identify which pipes its connected too, fully open both valves.
Finally you will need an Auto by-pass valve fitted into the pipework.
