Hidden shelf supports - how strong?
17 May 2013
I've an off-cut from a solid oak table-top I'd quite like to use as a shelf; it's 1m long, about 20cm deep, and the wood is about 4cm thick, so it's quite a hefty bit of wood.
I'd like it to be quite slick and was wondering about using some sort of hidden/invisible bracket rather than normal under-shelf brackets. A google search shows things like this exist:
But I'm a bit worried this would increase the torque applied to the wall, which is a modern internal wall (thick plasterboard on a 'wire' frame) so no bricks or wooden beams. With the shelf being heavy to begin with, is this a bad idea?
The other disadvantage is it means doing more damage to the wood of course...
Those blind floating shelves are generally pretty lightweight, and its essential that the bracket poles are at 90 degrees......for a chunky shelf, it would be side supports for me.
John :)
It might end up in a corner but I wasn't explicitly planning it that way; potentially it could be arranged so the length and one end are up against a wall but not both ends.
